1 - 6 of 6 Posts
Hi all, recently i have once again bumped into the same problem. My 2016 dragster rr starts fine but shuts off itself after few seconds. But when the rear speed sensor/abs jack is disconnected the bike starts and runs fine. If i connect the rear speed sensor/abs jack the same problem persists. I changed the rear speed/abs sensor with a new one but the same thing happened.
So the only solution for me right now is to disconnect the rear speed/abs sensor and ride the bike. Please guys if anyone of you can help me out it will be of great help. Thanks
Where in the world are you ??? Not in your profile.....
This sounds like that sensor is causing noise on the CAN-BUS circuit. You can test the sensor. Have you called your dealer about it yet?
The CANBUS is what distributes electricity to all of the components of the bike and all of the communications to/from the ECU.
Give GOOGLE a shot...it will help.
1 - 6 of 6 Posts
