What spark plag should I use for the CSTL ? What are your expierences? In the handbook the write Magneti Marelli 275, what does this mean about 60 years later?
Greetings
I'm going through exactly the same process right now. Manual says Magneti Marelli 275, but I can't find any cross references to that number in current day cross reference charts.
Mine is currently fitted with a champion L82YC. The L corrseponds to a 14mm thread 0.5" deep, which seems to correspond to my thread depth in the head. The YC is standard projected nose and a copper core. The 82 is the heat range. My plug seems a little dark in colour (Milk chocolate brown) which may indicate its running a bit rich, but the jets are standard in the carb, or that the plug is a little cold.
Anyone have any thoughts or know what the correct plug should be for a 1957 175CSTL?
