1 - 2 of 2 Posts
Hi Per.
This confussed me the first time i did it.
If you remove the selector mechanism and set the small gear into neutral ( i used a pair of pliers and just turned the output shaft untill i found all of the gears and was sure i was in neutral) this will help.
Then replace the selector mechanism so that the 2 dots line up.
To make sure your correct just go through the gears again.
It sound a lot harder that it really is.....honest.
Dorian.
1 - 2 of 2 Posts
