Hello guys. I wanted to ask you if you guys know if a Muzzy Fan from 2006 F4 will fit a 2002 750 F4 Fan???
Are the fans the same size or do 1000's have larger fan?
My 750 has two radiators, so it's newer version..
And will I see a drastic difference in temp. drop by just installing one Aluminum Muzzy Fan??
Thanks guys....all comments will be appreciated.
~Sergey~
Dave from Muzzy fans in the states 541-385-0706 about U.S $80.00
Google it.. he can tell you 100%, if they fit im sure they do.... i found i had to trim the blade tips as they hit the radiator when i spun them by hand...In the package from Muzzy there is a paper template to use, i just trimmed 5mm off the tips of the fan blade...i only run the bottom fan in aluminum as i take the top thermo fan off for track days..
the difference will be a few degrees Celsius 5-8.....the bike will still get hot if stuck in traffic but they do help....What country are you in....
When you get them go over the edges of the blades to deburr and smooth them. Very minor item but makes a difference in the airflow on/off the blades.
