1 - 9 of 9 Posts
I received my Arrows mid-pipe last week and was wondering if anyone who has installed one before could share their suggested install steps?
It looks to me like I will need to take the mufflers off in order to install the mid-pipe, would I also need to loosen or remove the header pipes as well to get everything to line-up properly?
Any need to use high-temp silicone on the connections or is it a slipon, spring-up and go process?
Any suggestions would be much appreciated.
Thanks!
There is an identical thread somewhere, but basically, take off the exhaust cans, remove the cat, and install the cans individually, then just bolt up, put on the springs, and enjoy!
Thanks guys, my biggest question was regarding the headers - I was hoping I didn't have to take the full system apart.
Fazer6 - I finally found the install thread you were referring to. I appreciate your help. Sorry I couldn't make it on a ride this past weekend - the wife's out of town this coming weekend so lots of riding will surely take place!
I also found a thin film of lube will help the tubes slide together easier, as mentioned they can be very tight! Also Loctite the bolts on assembly
I'll second that loctite comment. But use locktite blue not red. The red takes heat to break it loose.
True, very tight. I used a little wd-40 to coax the mid on.
Should have time and health to ride this weekend too, shoot me a pm or start a ride thread!.
M
Guest
+1 for blue locktite...
For the midpipe...I used a little motivation from a rubber mallet, and some extra ummmpphhh from my mechanic.
As soon as I get my bike back, I'll do up an install video for the mid-pipe and for the Thunder system I have. :)
1 - 9 of 9 Posts
