1 - 20 of 44 Posts
just installed the new microtec so now it is time for a test ride. Hope it is all it is made out to be.
I am in the same boat...just installed a new (used) Microtech. Need to go test ride, but work is interfering.
I will forward an email to you from Chris at X-bikes which has some set up instructions
better off throttle response and smoother through the range. The fans come on a little sooner also
Now that i have the alarm removed and she runs I will need to set the TPS....thanks for the email!!
Does your neutral light glow when it's in gear? Only got in a quick ride up and down the street tonight. Seems to idle well an accelerate smoothly.....but the headlight flickers on/off at idle and the neutral light only dims in gear???
I've got a steep learning curve, and haven't had enough time to study it yet.
To get my neutral light working properly I had to pop open the harness and wire in a capacitor. Don't remember where or who told me, but if you want, I can take a pic tomorrow.
Can someone youtube a microtec install, or still photo here?
Microtec
George, does the bike run cooler at standstill?
Yes it glows slightly and there is a tutorial to fix that in the email I sent you
Haven't ridden it enough to tell
After 5 years +/- of using and talking about the Microtec, I can't believe the questions being asked now, and no offence meant either, it just amazes me, where were you guys all this time. :stickpoke
George the info you sent to Ed has been available on my site, via Chris, others and myself for a long time, well done on finding it as you won't believe how many guys can't even open that basic email from Chris.
I'll have to update that part of the site too, so if you have anything new please send it to me too.:):naughty:
Now let us know what you all find, let others know too, I must be on block for some people. :jsm:
Discussion Starter #18
Dons you do an amazing job of collecting and handling information and keeping the site up and running. Most of the time people ask questions instead of searching because it is easier.
Chris from X-bikes has a quickshifter for me in stock which I will buy. It is for a standard peg shifter I believe and he does the modification for a rearset shifter using the linkage rod also. Do not have the prices
I just dove off into the deep end here Dons :ahhh:
..... Hadn't really studied too much about the Microtech units, just knew a lot of folks very happy with the change.
Gina was running really well with the MV Kit ECU....but I had this opportunity to buy Henrik's Microtech and thought...What the hell, let's try it out. :D
So I'm now on a steep learning curve and haven't been able to devote enough time to the educational process. :nerd:
1 - 20 of 44 Posts
