Depending of do you have spark in any cylinder? I would start with few things first.
- Ignition fuses
- Crank sensor resistance values
- TPS sensor values, yes it should not affect spark, but has done that to me
- Measure the coils (did the 2007 have twin pack of coils?)
- Check the ECU ignition wise
- And of course main wiring harness comes to mind
First pice of advice is to put your bike model and year in your signature line so the we don’t have to dig through pages of thread in order to figure out which wiring diagram and troubleshoooting guide to reference
Problem found, and it's not good. While checking the crank sensor (tested good) I realized I hadn't bothered to look down the throttles to inspect the valves. Well, No. 4 intakes are bent to hell and none of the other valves are moving when cranking the engine! Turns out my original diagnosis of failed cam chain/sprocket bolts was spot on! Don't know exactly what failed yet as I'm not digging any further at this point. Anyway, will reassemble everything and park the bike until winter arrives and I have time to yank the motor and strip it down. Really disappointed in MV at this point: easy 12k on the motor, great maintenance and yet it craps out on me big time. Definitely will discourage anyone I know or meet of every buying an MV product. Can only guess how difficult it will be to get the parts I need (I live out in the PNW farmland) and what they will cost. Time to get on one of my vintage Sportsters and go for a ride on something that actually runs!
Thanks for all your advice, only wish it had been something simple.
back in 2005:
"There have been at least two engine failures documented online due to airbox wellnut disintegration. The factory requirement is to replace the airbox wellnuts each time the covers are removed."
I replaced the wellnuts with aluminum rivnuts a long time ago so that wasn't a factor. Definitely believe the cam sprocket bolts are the culprit here since I read another account of this happening to another 2007 F4 owner.
back in 2005:
I never, ever would have thought of this one. I immediately walked out to the AGO and sure enough, two screws on ea side with 14 year old well nuts presumably holding them in.
Now I have to take the thing apart. Again
Thanks for posting this one. I gotta borrow up some common sense.
This why this forum is great for the MV collective. Glad the link was helpful.
On the side... I went out on my Brut today for a reprieve. Came across a down biker. He got clipped at an intersection in Philly. Please remember if anyone on this forum sees a biker down please stop and offer support. It goes a long way...
A forum community dedicated to MV Agusta motorcycle owners and enthusiasts. Come join the discussion about troubleshooting, maintenance, performance, modifications, classifieds, and more!
