1 - 10 of 10 Posts
Purchased a bike in april of this year, and went in for my 1000km. Had a few things that needed checking, like my throttle that was hanging/unresponsive. Also have a noisy chain tensioner, which the dealer says is normal sound. Will see how it goes with time. I was also complaining that the bike did not always start easily in the morning. Took longer to fire up than it should.
I qas surprised to see there was already a map update out for our 2016 bikes. Haven't noticed anything yet... Anyone else get it?
Not aware of the map update but interested to see what they say about early morning starting issues as mine is doing the same thing.
Have you tried lowering your traction control setting? I think it's a bit too sensitive on 8 and and can cause the throttle to not respond sometimes. It seemed to help my dragster
First thing in the morning mine on first start turns over maybe 1/2 second longer before firing up but fine when warm. If it starts in under 2 seconds don't sweat it. Throttle bodies need to be synced though I know that a biggy
Since having mine they have done about 3 map updates so I'm told, honestly I cant really tell much difference, maybe a bit smoother low down but a run a custom map anyways
Noisy cam chain is more likely a noisy engine, its italian and a triple so kinda accept that. Mines running sweet after 9000 miles and alot of abuse
As mentioned previously the traction control is primitive at best. Anything above 4 and you're going to find it unresponsive on spirited rides. Keep it at 3 max and you'll have no issues, if you ride hard on road/track then Id say 2
If its still unresponsive after this then yep you got an issue right there
Thanks for your input!
Their update did not fix the long starts in the morning. I don't think a starter clutch could cause this though. It turns over fine, just doesn't fire up.
We've had the same issue at work ( I work for subaru ). Our issue was a can sensor that needed a smaller shim for the gear to trigger it. It would then fire up.
What do you mean custom map??? I've been tuning my maps and ECUs for years and haven't found anything to get in to my ecm. Mind pointing me I'm the Right direction??
Thanks!
Hey Wrick
Search for Sprag Clutch, it definitely could be the problem. Symptoms of the issue also includes engine turning over but not firing up. Weak battery and sprag clutch issues go hand in hand with these bikes. One being faulty could cause the other to fail also.
I got the canister out yesterday, will see about the longer cranking.
It just turns over, no weird noises nothing.
You have 4 settings for fuelling on the bike. Rain, Normal, Custom and sport. These are accessed by pressing the start button when engine is running. The custom setting allows you to change the fuelling and engine braking etc to your preferred settings.
If I were you I would first balance the throttle bodies. Mine ran like a pig till I balanced the throttle bodies and now runs sweetly.
What Squidger said, its not getting into the ECU as such its something the bike can do from the menu
Run everything in sport except throttle response, put that as road
1 - 10 of 10 Posts
