1 - 9 of 9 Posts
Brutale Dragster 800 RR MY15
Curious to know whether others have experienced the same or similar?
Couple of situations, both quite different, where there seems to be a lag when opening the throttle to power being delivered.
Situation one: when going over a small bump or similar in the road, the power drops off and then is re-engaged. The whole process is very quick which possibly leads me to being a TC thing.
However, situation two: When going from a standing start and not aggressively riding. i.e. say down a 90 deg left turn (UK roads) the power is delivered, but not for the amount of throttle that being used.
It then comes up to the correct acceleration for throttle application after a couple of seconds. It's almost as if a lean angle is involved in not allowing the power to delivered.
The speeds here for situation two are circa 10mph.
Anyone have experience of what this may be?
What is your Traction Control Setting?
This happens to me on my Brutale Dragster 800 RR MY18...power only seems to re-engage when I let off the throttle then open it again.
My TC is set to 2.
I dont get the other issue. My map is set to Sport and TC2.
Hope this helps
MY 18 Dragster RR... TC set at 5, normal mode: no issues with throttle as you describe.
It's on 8. But the second situation... Why would it happen when the bike is going so slowly? TC just shouldn't kick in at such a low speed.
8 is very intrusive. If it senses any wheel slip at all it will intervene.
Why do you need the setting so intrusive?
I'd suggest 2.
I agree, perhaps try a lower TC setting? Maybe ask your dealer? Optimal TC and ABS settings on my new Dragster are a question for me. Time to start playing with them. I do note TC here, while riding through one of our occasional Texas Gulf Coast apocalyptic rain storms, did a nice job defeating wheel spin.
Your TC is set to maximum, that's what you're feeling, the bike is detecting rear wheel slip of some sort and it is cutting in. Try a lower setting.
Also if you are in "R" it is not race but Rain. Try N or S if you don't want to set up a custom setting.
1 - 9 of 9 Posts
