1 - 10 of 10 Posts
· Registered
Hello everyone, just joined this forum. Don’t know too much about MV Agusta… perhaps because it was too costly to own but I have just purchased 2015 dragster 800rr. I’ve been reading and watching video after video trying to learn more about this monster. Anyways, just out of curiosity but can the newer model back turn singles and license plate holder fit with older models without modifying…? Thanks
· Old Wing Nut
Welcome to the family !!!
What are you trying to achieve? And by newer, what year model are you referring to?
Some newer bikes have LED lamps that can require more than just a swapping of parts as the flash rate will be wrong.
Tell us more about you new MV, share some photos, tell us about riding where you live.
· Registered
Discussion Starter · #3 ·
I have the stock fender / license plate holder/ led turn signals….for 2015 dragster 800rr… I see the newer stock models turn signal and hoping that mine can be replaced
· Old Wing Nut
I am sure they can be used, but you will have to also get the mount or fabricate up something. Pretty sure the mounting will be different.
Then again, maybe not. Is there somewhere you could go look at one to compare? Electrically there will be no problem.
· Registered
Brutale 800 RC
For the signals, all „Relais“ are the same.
i replaced my 2019 Relais with an old one to be able to fit standard turn signals with 12V.
the newer ones have 3V only.
· Registered
Brutale 800 RC
You could go only and see if the mechanics fit. the bigges issue would be mechanical fitting of the plate holder.
as said, you could simply exchange the Relais against a new one.
1 - 10 of 10 Posts
