Has anyone come up with a good License Plate Holder to mount under the tail?
There's got to be some random Tidy Tail Kit that will bolt up to the Rivale under tail plastic cleanly....?
I've seen a couple photos of guys who have done it, but no one has listed a part number or Kit number.
Here is what I did for mine. Took a universal holder found on ebay which had at least a center to center lenght of six inches for mounting holes. I went in from the inside of the tail and there you will find some welnuts that have been welded into the subframe. I sourced some bolts cut them to size and drilled. Once you remove the fugly tag holder you will need to order two OEM bolts to replace the longer ones that hold the assembly to the hub. The ones from the F3 work perfect. i re-routed the wires up and into the tail where i used the tail light wires to connect the plate light. I did not add blinkers since i dont like the way they look.
looks a lot better...
