I need to swap out the left side engine cover that says F4 on it. Is there a gasket or sealant I have to replace when doing so? I just wanted to know before I make a mess (because I park my bike at work).
There is a rubber O ring that goes round a channel inside the "F4" engine casing end plate. You should be OK re-using it. I also put some gasket sealer on the joint to be on the safe side.
I thought about getting that emoto part but my side fairings are carbon and the aluminum plate looks good there. Does anyone make any thicker aluminum ones?
The Dude
