1 - 6 of 6 Posts
Hi there
Went for a great trip today and suddenly my left indicator light stopped working. Both front and back. Checked the bulps by connecting the left light to the right side switch. They worked, so bulps and wires works.
Fuses checked as well.
Good ideas would be much appreciated
Hi Cag.
Hope not - but could be. Do you how I can check that?
Mikael
Had the same problem with my F4 yesterday.
Fix it today.
Try just by switching the light bulbs. Then you will know if it is a problem on the bulb.
Mine was not broken but I drove on the rain and as the exhaust was hot the water evaporated on the blinkers.
I had to clean the wires, eletrical fixations, bulbs etc. Changed to new bulbs and connected everything together. Now it works fine. Guess my trouble was just some condensation on the wiring.
Try that first, Don't forget it is an italian bike, and as every italian girl it is cranky and doesn't like wet weather.
cheers,
m
This (att.) is from the workshop manual
However, I would first check for voltage at the fuse (5A) and the voltage is 12V and not less, if the fuse is all OK (A&V) then check the connectors and wires between the SPU and the turn signal.
Thanks guys
I now have a to do for the weekend.
Best
Mikael
1 - 6 of 6 Posts
