1 - 3 of 3 Posts
Ok, I know this has been discussed here but the vendor states it's
"Plug-N-Play" for these LED replacements on my Dragster RR.
Question: Will these require a resistor of some kind?
Thanks in advance.
W.
"Custom designed PLUG & PLAY LED front turn signals for the MV Agusta Brutale. These turn signals fit the 675, 800, and 800 Dragster models. Designed to mount flush to the same location the stock turn signals were, these provide a sleak looking replacement.
Save time on the install and more time riding with our line of plug & play accessories.
CNC machined from billet aluminum using 1mm LEDs, giving you extremely bright signals .. Day or Night!"
http://www.newragecycles.com/MV_Agusta_Brutale_675_800_Front_Turn_Signals_p/brutale-drag-fs.htm
No mention of adding resistors,they say plug and play so you should be OK.
If your replacing LED with LED, it shouldn't be a problem.
1 - 3 of 3 Posts
