I just received mine
I just received my set of Invisigard protectors. Sorry can't tell you how they look just yet, but if the results are similar to my efforts on installing tank protector pads, I might just look for a pro to do it. I am afraid of introducing air bubbles.
Very easy to do...They almost disappear into the paint, very cool. Here's my tips...
1. Read the instructions all the way through once or twice to gain familiarity
2. Use the solutions (Denatured and soap) from the instructions EXCTLY as described
3. Work inside - away from wind, dust, bugs, etc.
4. Make sure your hands are very clean, spray finger tips with the solotion you are working with at each step
5. Take your time, start with the smaller peices to get experience, before going big.
If you closely follow the directions, your results should be fantastic. Mine came out great, and I had never done it before.
Good luck,
Griff
twoeleven
I fitted the kit to my 1000S, it looks ok...............but not as good as without it, and as a mate of mine says why protect it for the next owner? my new "R" won't be having it except perhaps on the tank sides were my leathers rub
I was just thinking about using just the headlight piece but was worried about it handling the bump in the middle of the headlight. Any comments on thoses who have applied it?
Thanks,
