1 - 10 of 10 Posts
I've been searching around the forum and haven't seen anything on this topic.
My question is: should I remove the fuel rail to access the injection plugs that I need to plug the PC3 into?
No you do not have to remove the fuel rail. Just the tank and air box
Ok thanks, The plugs are pretty tight up under the rail. So I thought I would ask first. Thanks again.
I discovered the plugs rotate on the injector. Just rotated them outward and simple as that.
BE VERY CAREFUL OF THE INJECTORS WHEN REMOVING PLUGS....
they are fragile.......press the clip and pull STRAIGHT back
:popcorn:
Not saying you can't fit PC3, but just do you know, I had PC3 on my 5SM Brutie installed by the 'pros' and no end of trouble running too rich. Junked it for the Microtech.
EDIT: Idle was playing up too. Hope the PC3 is better now, that was with dyno tuned map. A couple of times actually to get it right.
What ECU did you have squibby ,I thought the PC5=5SM ECU,Just curious,as mine is brutale b4 1078rr 5sm using PC5.
CHEERS EDDY
1 - 10 of 10 Posts
