1 - 20 of 61 Posts
Sstripped my 1078 for its 60,000km service and I have some carbon deposits on the backs of a couple of the inlet valves whilst the others are quite clean. I am probably worrying about nothing and am not going to strip the motor on account of it but wondering if there is any additive or different fuel ( in Australia) that might help. It was much the same at 48.000ks . Any theories on why this would be ?
cheers Cus
In our case this is mostly caused by oil coming past a valve stem seal, or sometimes a rich running engine, but others might be able to give you more info on this Cus.
I've seen people use SeaFoam to clean the system - http://seafoamsales.com/sea-foam-motor-treatment/ but I imagine there's a lot of option out there these days.
I could get in there with something to loosen the worst of it but wouldn't want any of it lodging on the valve seat and holding a valve open.
Checked out the sea foam site, looks like it`s worth a try, I will see if it is available here. Yanks get all the good stuff.
intake valve seals......
and believe it or not the cheapest place to buy them....... the dealer:jsm::jsm::jsm::jsm:
I kid you NOT
:popcorn:
Quite some time ago after a service it became obvious the air filter had been massively over oiled as in running down the frame and making a hell of a mess when the bike was warm. I just twigged the two valves with deposits are on the low side of their respective throttle bodies when the bike is on the side stand. What`s the chances the excess filter oil created the deposits ?
cheapest fix ......Marvel Mystery Oil, been around forever, add the recommended
amount to your tank......
I use it in all my air tools too
:popcorn:
Cus,there is a product on the market to clean intake track and remove carbon deposits.I highly recommend it,I use it on cars I service and it is brilliant.Any Repco store sells it.Threebond Engine Conditioner,try it.
Hum let me think......
Marvel Mystery Oil was patented in 1923
Ring Free was patented in 1937
And what did the Japs have to do with it Ed??????
Yamagook stole the name because the patent expired
Those of us that listened to Indy in the '50s and '60s remember the Ring Free Special cars
Yamaha Motors Corp was founded in 1955 after their success in copying the DKW RT 125
:stickpoke::stickpoke
:popcorn:
Brian;
What I'm going to do is grab some samples and see if Rob will run them through the
lab........trust me Yamaha doesn't make Ring Free
Rob runs the lab at a small local company...... Chevron Corp.
For now I'll take
Marvel Mystery Oil
Yamaha Ring Free
And maybe Sea Foam
Any other suggestions?
:popcorn:
I'd be curious to see your findings Noel......,I have Ring Free on the shelf...,one thing is for sure it is definitely not pink in colour like Marvel Mistery Oil ?.
Maybe a 'similar' product......,like Coke versus Pepsi?
Brian.
Googling....around the quoted forulae are real close......except for.the "proprietary"
solvent in Ring Free.....which is BS
With a little luck Rob will run it through the spectrograph.......
And we'll know
:popcorn:
Also get the Mercury Marine power tune to analyze......and some Lucas engine cleaner.....there's a slew of stuff out there.
I have Marvel Mystery oil...I use it to oil my air tools.
Dribbling brake fluid into the intake of a running motor will also knock out deposits....ATF too, I think. Hell, water was used to decarbon combustion chambers by some old mechanics I used to watch working when I was a child.
Yamaha used to use Chevron as their primary oils and chemical supplier. I think it's Shell now. Suzuki uses Shell for a lot of stuff. Shell uses Lubriplate for the additives in Suzuki's oil products.
It's all just a big "shell game".... Get it? :stickpoke
Brian.
Doesn't smell like it either......
This is interesting as I have read a lot of "expert reviews" of these products. Some say the are great, some say don't use them.
I'm looking forward to what Noel can find out.
Chuck, the Yamaha RingFree was actually a product for the Marine side of their business, originally developed for the 2-stoke outboards. 2-stroke piston rings would gum up, sticking in the ring lands causing loss of compression/performance.
Then the motorcycle guys found it did a good job of cleaning combustion chambers. I've used it with excellent results. I believe it is a concentrated dose of Techron (Chevron's gas additive they advertise as thereason to buy their gas).
1 - 20 of 61 Posts
