In the process of fitting sequencing LED turn signals to my B4 750, which need a direct feed from the switch rather than being controlled by a turn signal relay.
So I need to bypass the relay, problem is, I can't find it!
I've checked the wiring diagram and electrical parts chart but neither show a relay, can anyone tell me where it is please?
Hi not sure of your bike model.
On the 2016 Brutale the relay is attached to the headlight casing.
Remove two screws either side of the headlight gently pull it forward and the relay is attached to the casing with a thick rubber band.
Hope this helps..
Looking at the wiring diagram for the 750 B4 would suggest the intermittency is ECU controlled.
Usually, just wire to existing turn signal wires and install an inline resistor to slow down the flash sequence.
