1 - 19 of 19 Posts
Looking for the standard 2 pin indicator connectors that MV used on the original F4's, actually just need the female indicator side, not the loom side.
I know Dons got them from RS but I can't get the link to work.
Is there a name / manufacture for them ?
Adam, have you found what you need?
If not I can have a look on my "Spare Parts Bench" this weekend.....
Well that certainly worked lol - just mention the topic of the month.
I have a single seat unit on the bike at the moment which I fitted with leds for the indicators. I kept the original MV connectors by using the cable from the original indicators. I want to do something similar to my 1+1 tail unit so I can just swap between them for the very odd occasion I might go 2 up.
It would have to be the cable from the indicator side though, not the loom.
Thanks for looking...
Adam
I'll have a look in my rat's nest....
There are some suppliers of wiring connectors out there in the Ethernet mist. Just have to ferret them out....
One I have found full of good stuff is cycleterminal.com but I don't think they have those little round 2 pin rubber things. But they are made by a supplier to MV along with all the other wiring connectors. Have to be out there somewhere.
If we can decipher the manufacturer name we can find them......
I love a good Google search!!
Those are similar, but the MV connectors are stepped and polarity specific so they can't be mis-connected.
Well £1.95 wouldn't have broken the bank but looks like a no go..
Do the aftermarket indicators generally have the standard connectors ?
Maybe the integral rear light is an option for the amount of time it will be used..
Don't you guys have RS Components in the UK, I'm sure I added part numbers somewhere along the way which should be universal ?
http://au.rs-online.com/web/p/industrial-automation-circular-connectors/3412995/?origin=PSF_435588|cav........ RS Stock No.341-2995
http://au.rs-online.com/web/p/industrial-automation-circular-connectors/3412967/?origin=PSF_435588|cav ........ RS Stock No.341-2967
http://au.rs-online.com/web/p/circular-connector-contacts/3413049/?origin=PSF_435583|cav ............. RS Stock No.341-3049
http://au.rs-online.com/web/p/circular-connector-contacts/3413033/?origin=PSF_435583|rel ............. RS Stock No.341-3033
..................etc.
See post number 1 Dons...
I saw the 1st post Adam, I don't know which link you're referring to though, but if you used the part number from RS Components, it should work in their search box regardless of which Country you're in.
That's them !!! Adam, links worked for me.
It was half a link from a link, can someone post the RS part number as it didn't show on the page I found....
Here ya go:
Manufacturer ITT Cannon
RS Stock No.341-2995 Mfr. Part No.120-8551-100 female connector
RS Stock No.341-2967 Mfr. Part No.120-8552-100 male connector
RS Stock No.341-3049 Mfr. Part No.031-8703-100 female crimp terminal
RS Stock No.341-3033 Mfr. Part No.330-8672-100 male crimp terminal
Let me know how you get on Adam.
I can still dig through my pile of spares this weekend....
Yup.
120-8551-100 | ITT Cannon Mini Sure-Seal Series, 2 Pole Connector, MSS 2 R Shell Size | ITT Cannon........ RS Stock No.341-2995
120-8552-100 | ITT Cannon Mini Sure-Seal Series, 2 Pole Connector, MSS 2 P Shell Size | ITT Cannon ........ RS Stock No.341-2967
031-8703-100 | ITT Cannon KPTC Series, size 7 Female Crimp Contact for use with Mini SUPER-SEAL Connectors | ITT Cannon ............. RS Stock No.341-3049
330-8672-100 | ITT Cannon size 7 Male Crimp Circular Connector Contact | ITT Cannon ............. RS Stock No.341-3033
Here:nerd2:
I did.:surprise:
Here ya go:
That's exactly what I posted on page 1 :smile2:
Thanks, all, got the numbers now as the post before that Dons re-quoted cropped the part numbers of it...on my phone
However, I will try and get them elsewhere if I can as RipOff Supplies want £23 for 2x connectors with pins....
Adam
1 - 19 of 19 Posts
