This may have been posted I tried a search didn't find what I was looking for. I purchased a used water pump assembly from a 02 f4750 and installed on my 07 1000r. Mounted up perfectly but seems a little hot still. Are the impellers the same or should I swap that out? Any input would be greatly appreciated. Thank you
As Joe said...they are the same.
Check out my thread.....It shows comparison photographs of the standard water pump & impeller..,the 'upgraded' MV Agusta one & impeller ...,and the 'Design Corse' high output water pump...it's installation and result.
Hope this is of help...http://www.mvagusta.net/forum/showthread.php?t=43995
Brian:)
messiahmv;
you have to change the impeller and the outer housing with the HO factory water pump
:drummer:
Tell us why you did this in the first place if you don't mind ?
