1 - 10 of 10 Posts
Do we have one? I was under the impression all vehicles had to now, however my MV keys dont look big enough or right type to have a transponder in them. (They are the original keys).
Not an issue, Im just curious.
Mines a 2003 and does not, it did have a CAT 1 alarm but removed to bring the loom to standard. they make a mess of the wiring. All good now :)
Cheers. It was a EU rule that all vehicle sold after 2003 had to have an immobilizer but I guess MV were exempt as a small manufacture. Even Aston Martin are a small manufacture so exempt (tho clearly they all have them)
My F4 1078 has one, the new B3 800 RR not...
The units fitted to UK bikes had an immobiliser (at least mine did). The unit fitted to mine was a Datatool S4. This is a combined alarm immobiliser, armed when you turn off the ignition. Other Dataool alarm/immobilisers also seem to have been used.
My bike is an '05 F4 1+1s. There was a fitting certificate provided in the paperwork with the bike (by Aygees (sp?) motorcycles).
I removed mine earlier this year because it failed and wouldn't disarm.
I think he is talking about the built-in system that is passive. My Guzzi has this. No alarm, just a passive chip in the key and a sensor in the cluster/ecu that will not allow the bike to start without that handshake with the key.
No FOB or anything, its built into the key. Its usually indicated by a flashing light on the dash when the bike is off.
Not the alarm. My MV doesn't have that built-in system. I haven't seen one that does (but I suspect the new models probably do).
Yes thats what I was meaning. Cheers
1 - 10 of 10 Posts
