Im rebuilding a bike for my friend after he highsided it wich broke part of the side frame .... i have striped every thing off trailing arm ... all the bolts are out of the side frame even the other side has nothing in it holding it together yet it still wont budge from the frame i believe there is like a washer/collar like a dowel between the frame and the side frame ... but i cant work out how you get this apart its like i need to widen the frame by about 10mm to split it apart from the frame itself .... any advice would be really appreciated as im a little stuck .
Ah. F3 I don't know, but if it is anything like the F4 you have to lift the frame from the engine till you have enough space to get those washers out.
Thanks for your reply you confirmed pretty much what i thought i manged to do it all today what a pigsh*t it was but its all back together minus the fairings as im spraying them different colours but glad the hard bit is out of the way .
