1 - 13 of 13 Posts
Hello
This is somewhat long rant so bear with Me.
I have a slight problem with my high-sided MY10 F4 and would really appreciate it should some one give Me a solid piece of advice how to handle it.
While the bike inverted the ignition lock touched the track and the outcome was cracked plastic around the lock itself and the head of the inserted key being knocked off.
(Headlight, instrumentation, clutch lever tip, engine pick up cover and front brake fluid reservoir came off as well. Luckily no damaged main oil gallery.)
The copper wire of the immobilizer ring antenna is visible through the cracks but the stub key turns with ease and the dash powers on OK.
Nonetheless I want to replace the ignition lock/immo antenna before they suck up water through the cracks and start to malfunction.
The question is has anyone got experience or solid info on this one:
Can MV-Agusta deliver - based on the mechanical and electric code provided with the bike's code card - a replacement lock rekeyed to fit the same key as the other locks of the bike?
(Basically I want to retain the 1-key system)
I'm sorry to bother anyone but Our domestic MV importer with this, but apparently they seem to have quite limited knowledge on all things MV, nor interest in them for that matter.
(They sell quite a lot of Husqvarna dirtbikes, and I suppose ended up with MV due to Cagiva-Husqvarna connection)
So far they have provided Me with the following information:
1) 2010 model does not have an immobilizer (This stated 2m away from 2010 bike that has "ZADI Securnet immobilizer" text on top of the ignition lock.)
2) Yes they can recode the keys, if the ignitionlock is replaced.
3) No they can't and the instrument panel has to be replaced as well if the lock is swapped.
At this point I thought it's better to look for other options.
Third party providers code key blanks for ZADI Securnet immobilizer equiped bikes like Aprillias, KTMs and so on.
All they need is the part that has the immo functions (dash, ecu or separate immobox varying on make.)
So this is not a problem.
Rekeying the new lock might be.
So long story made short:
I'd like to have one key to fit all the locks of the bike without replacing rest of the locks and/or the dash in the process. (Edit: I have the original dash of the bike replaced under warranty due to the "dust inside dash" issue, hence I don't want to buy an other one. The new one was demolished during the high-side.)
Best backup plan I came up with was to have a locksmith transfer the internals of the old lock to the new one and duplicate the old ones spare key - should MV turn out to be incapable of delivering the lock rekeyed for the same key.
Suggestions and information on the subject is very welcome.
Discussion Starter #2
In addition, has anyone seen any kind of crash protection for the key/ignitionlock combo ?
What I heard from Italy I'm far from being the only one that has the key and/or lock written off when the MY10+ bike rolls over.
The old style location of the lock in the front of the gas tank/airbox was way better crash-wise.
keys and Zadi immobilizer?
Gatling;
contact Jim Hamilton
www.allmotorcyclekeys.com
he works with everyone on the Aprilia Forum and Aprilias have Zadi systems
tell him i sent you
i have an Aprilia blue master key and sent it all over the World, Jim made that unnecessary
Thanks a ton guys.
Yes the Star Twin guys have been very helpful in the past, so it's well worth supporting them even if their shop isn't the cheapest around.
The situation is as follows:
I actually allready bought a new lock from an other vendor, but when disassembling the old one found out that, while the plastic splash guards around the lock and the immobilizer antenna + the key in the lock were totalated, the lock itself was mechanically sound.
So I cannibalized the plastics and the antenna from the new lock and put the whole thing together.
I have the unused key no.2 that came with the bike and just need to get an other one for spare and teach the immo to recognize it.
I measured the new ring antenna and the coil + wires have 14,3 ohm combined resistance.
As buying a complete lock from MV is sort of a pricey way to get one, I thought that I'd ask if some one at some industrial coil rewinding shop could figure out the specs of the coil judging by the coil dimensions, wire thickness and resistance.
Perhaps it could be possible to make some close enough or find a substitute antenna from an other Zadi lock, more readily available at breakers - should someone else flip MY10 F4.
I allso thought of making a spacer between the top triple clamp and the lock bracket to relocate it lower to make sure the key head does not stick up from the triple clamp top surface level.
The lock moves with the steering so it might interfere with the instrumentation bracket.
Perhaps a protective part pinched between the bracket and the triple is possible.
Got to have a good look at it.
new Zadi keys?
Gatling;
i told you who to contact.....
your key sends a digital code to the Zadi Immobilizer, an Ohm meter won't help you
the Immobilizer will recognize up to 4 keys
Aprilia has used this system since '03, Zadi keys are difficult to cut.....at least locksmiths screw them up all the time:stickpoke
once you have a key that turns the lock, you need the Blue Master Key to make the Immobilizer recognize the new key.....
I have one for Aprilias, i don't know if the MV Zadi Immobilizer uses the same Master Key
the simple easy way around all of this is to contact Jim Hamilton, he will cut and clone your key so your new key is electronically the same as the original......one day turn around:naughty:
BUT, IT WON'T LOOK LIKE AN MV KEY......but it won't cost like one either:stickpoke
http://www.apriliaforum.com/forums/showthread.php?182209-trouble-shooting-and-maintenance
go to post #1, item #15
http://www.apriliaforum.com/forums/showthread.php?203485-list-of-locksmiths-that-cut-Aprilia-keys/page3
do it the easy way go to Jim:drummer:
cheers
Gatling;
<snip>
cheers
Hello
Thanks for the tips.
Yes I took Your advice allready in the first place and will contact Him when it comes to the spare key.
The point of the coil speculation was that I now have a (new unused) extra lock, minus the antenna and cover plastics.
I was thinking of trying to find out the winding specs of the immo antenna coil to see if its possible to replicate it within reasonable cost. (Or utilize one from another Zadi system more common at breaker's than 2010+ Agustas)
If possible it would make the lock usefull for a say a trackday bike that has less emphasis on appearence. Improvised immo antenna and splash guards would do just as well as the glassfibre fairings and so on.
People that restore classic bikes have generator and ignition coils rewound all the time.
Besides I'm pretty sure other MY10s will be dropped on track in future as well and end up being damaged in a similiar way.
I'd imagine the owners might be pleased to know if there is a possibility to replace the immo antenna in a more inexpensive way than buying the complete lock assembly from a MV dealership.
Hello Gatling,
I'm in more or less the same situation you are in. Could you please help me by providing the information you have gathered. My story is long too, please bear with me...
I bought a used 2010 MV F4 four months ago and I got only one key from a reseller in AZ. I LOST! the only key 10 days ago :( and I do not have the code either. I called 2 of the major dealers around San Diego and they said I have to replace all the three locks and the Instrument panel, and the painful part is , the quote they gave me. They both said it would cost me over $2000 USD which almost gave me a heart attack.
What are my alternatives? Please kindly suggest. I will be eagerly waiting for your response.
And also fellow MV Riders, if anyone of you have any suggestions please email me.
Sincerely,
Manny
Hi Noel,
I have read your posts and I am writing with great hope. I lost my only key of 10 MV F4. Please advice.
I live in San Diego and I have contacted GP Motors and also Moto Forza, they said they cannot help.
Please advice.
P.S: I will also contact Jim first thing in the morning.
Manny
Manny;
it's very simple....
the Immobilizer is there for a reason......to stop thieves
you lost your only key.....
the dealers you went to are personal friends......they are protecting the MV community from assholes that want to make track bikes out of stolen MVs
Jim Hamilton will help you if you have a key shank and the chip (a broken key)
otherwise you need a lockset
I have a Master Key for Aprilias so you can link a new key to your Immobilizer
I've sent it all over the World......try to borrow it without being a known Forum member:naughty:
and a Russian cocksucker "muffler" kept it.......Forum members chipped in and bought me a new one
Good Luck
Manny;
Good Luck
Hi Noel,
Thanks a bunch for a quick response.
I locked the bike in my Garage and it is sitting there for about 2 weeks. I'm pretty sure I dropped it on my way back from the garage to my apartment. I've checked with my apartment leasing office and even posted flyers in front of my garage thinking someone might have found it and will return it. I even offered a reward. But who ever found it did not return it :(.
I've been going to GP since 2011. I also have a 2011 Aprilia Shiver. I get it serviced there very often. I will go talk to them in person. May be they will help :(.
So if I got it right. I can get a key cut only if I have a spare.
In my case, As I do not have a spare, getting a new lock set it the only option ? Please Advice.
And also I have found ignition on ebay :
http://www.ebay.com/itm/2010-11-12-MV-AGUSTA-F4-1000-1000R-ignition-switch-module-gas-cap-key-oem-/321418673617?pt=Motorcycles_Parts_Accessories&fits=Year:2010|Make:MV+Agusta|Model:F4&hash=item4ad60bbdd1&vxp=mtr#viTabs_0
Do you know if I can use it ? SoCalMotoParts is selling it. Anyone know them ?
Manny
Hello Noel,
Thanks for the quick response.
I've been kicking myself in the butt and also places where it hurts the most every day for loosing the only key I have, for the past few weeks. I am sure I might have dropped it on my way from the garage to my apartment (I have one of those detached garages). I checked with the apartment leasing office hoping someone might have turned it in. I even put out flyers offering a reward. But no one turned it in.
I know what you are saying, and it is in the best interest of the owners. But I am not one of those guys you mentioned. I also have a 2011 Shiver which is serviced regularly at GP. I use it for daily commute. I will go in personally this afternoon to ask for help. They might not recognized me over the phone.
So Noel, As I dont have a spare or the key code, you are saying Jim Hamilton cannot cut me a new key correct ?
I saw a lockset for sale on ebay, sold by SoCalMotoParts.
http://www.ebay.com/itm/2010-11-12-MV-AGUSTA-F4-1000-1000R-ignition-switch-module-gas-cap-key-oem-/321418673617?pt=Motorcycles_Parts_Accessories&fits=Year:2010|Make:MV+Agusta&hash=item4ad60bbdd1&vxp=mtr
Do you know if it works ?
What are my alternatives. Please Please let me know.
Manny.
Oops I did not see the message I posted earlier, so I wrote this again after coming to work. Sorry. I saw page two in the bottom and then noticed both my messages in page two.
1 - 13 of 13 Posts
