1 - 18 of 18 Posts
I m putting on a new gold chain, is it neccessary to change sprockets? Sprockets looks fine with 8000 miles....
its always a good thing to change everything at the same time. that way 4000 down the road you dont need a new rear sprocket and not a chain
Conventional wisdom says yes..change all at same time....one reason is even slightly worn sprockets will accelerate the ware on a new chain and reduce its life......its cheaper in the long run!
MV Cellist
totally agree...
Just curious, how long do the OEM sprockets last with good care? what are people's experience?
Lots of variables determine chain/sprocket life such as chain tension, sprocket hardness, lubrication . . . oh I'm getting excited now. I always replace as a set . . . just put a 520 conversion on my R1 last month right before buying the Marchesinis. Why didn't somebody tell me OEM sprockets wouldn't fit them? Now I get to buy another set :bawling:
Hey Chris did you know that the OEM sprockets wont fit on the Marchesini wheels!!
BTW my R1 is now an LE as well full ohlins :p but with "gold" marchesini mags :naughty:
:guitarist
JamesC said:
I use FBF's quick change and thus their Alu sprockets. 6k mi/two oil changes with good care.
is the quick change really only applicable to the 750? the 1k has a quick-change setup on it already - as far as i can tell...
alex
Are you one of those rap artists. Darth? Gold chain geddit!! :laughing:
:guitarist
Thanks, now you tell me. :cussing: So I got you worried, huh? Afraid you won't be able to keep up? :stickpoke But are you getting wave rotors and titanium bolts :loser: Since I was buying gears, I ordered stock and -1 CS, +1 and +2 rears just to have a complete set.
darthmvader said:
its all about the bling bling....
Joking aside I think it will look good Darth. :smoking:
alex
Depends on if you want to buy the FBF replacement sprockets or OEM sprockets. The carrier fits both as far as I know.
1 - 18 of 18 Posts
