1 - 6 of 6 Posts
When I see that my Brutale is almost not being used, I have decided to put it away. As it is now, it will be more useful to stand in the hallway at home.
The question then is which preparations should I make? Should I empty it for oil, coolant, fork oil and more? Or is it enough if I empty it for gasoline?
The plan is that I will bring it back om the road when my children are old enough to drive.
Rid it of gas, pull the battery, spray a cylinder protectant in through the spark plug holes and call it a day.
It takes a lot of discipline to leave a bike for that long.
As an alternative, would you consider a 'test store' of say, 6 months? If so, just put appropriate fuel stabiliser in tank and battery on tender.
Then, if you're committed to long-term store follow advice above:wink2:
I would worry a bit about leaving the clutch and brake fluid for that long. Perhaps change them annually?
Change the brake and clutch fluid when making the bike roadworthy again.
Drain Gas, pull battery, get cylinder fogging oil and spray into motor from plug holes
1 - 6 of 6 Posts
