Co sensor underneath, on the exhaust none on the E2 and present on the E3 as far as I can remember. Help Ed if I'm wrong.
And a bit harder to spot, but different ECU, 1.6M on the E2 and 5SM on the E3.
Look at the valve cover....if it has square caps between spark plugs 1-2 and 3-4 with rubber hoses connected then it is a Euro3....
There are other tips including the o2 sensor, but that may be missing if the bike has a kit exhaust and ECU.
pull the left side cover with a flashlight you can see the 2 red plugs in the 5SM ECU
then there can't be any question
Ed; I'm looking for the earlier valve cover.....the silly block off caps from the auto parts store keep cracking.....
Chinese rubber and LA ozone.....bad combo
:wtf:
