1 - 1 of 1 Posts
Remove the F4 cover
Using a 19mm 12 point wrench, see which bolt hole the handle comes closest to
I used a narrow strip of electrical tape to tighten the wrench on the nut, you could drive toothpicks in too
Use a longer 6mm bolt and screw it in
Tie the wrench to the nut
Tie the wrench to the bolt
You can use good string or fishing line too
Crankshaft won't move :grin2:
1 - 1 of 1 Posts
