What are you lubing the chain with?
Switch to something cleaner with less fling, and apply it properly (i.e. hot chain, apply, wipe off excess).
Where I live it seldom rains so since the orings keep the lube in the rollers I don't use chain lube any more. No rust issues. I do use wd 40 to keep the orings from drying out and clean the chain. After lubing following a ride and wiping off, it seems to do well. My neighbor turned me on to this and he gets 30k out of his chains. I is low humidity here as well. (S. Cal)
Just my .02 worth.
Fala José Paulo,
Tive este mesmo problema por lubrificar demais a corrente. É só diminuir a quantidade que fica tudo certo. Eu uso Motul Chain Lube.
Abs,
Raphael
