Since dropping my F4 last week, I've become a bit nervous of the side stand. It was my fault it went down, but I can't help thinking my bike tends to lean a bit further than other bikes on its stand, and I have to lean it a long way to set it down, (which makes it easier to drop!)
I've checked the mountings and they're all secure, so it's not like its working loose. Are they all like this, or is mine bending with time? Are the stands on later bikes any longer? I quite often put a half-inch block of wood under mine if it's parked on anything other than the flattest of surfaces, and I can completely forget about trying to park it on the left side of a road with a cambered gutter.
Are sidestands Tamburini's Achilles heal? Was the genius sleeping in that class? :)
Si
it's supposed to lean that far. it gets more attention that way.
You can always put a small block of wood under the sidestand when at home to keep it more upright. No more than an inch (25mm) in height should do it...
Not yet being an F4 owner (tomorrow I pick it up) I seem to remember that the rear ride height is a bit adjustable? If its set too high then the bike will lean more. The good part about a higher rear ride height is the bike turns in faster!
Correct me if Im wrong.
That's a good point. I had my bike set up a couple of months ago at Baines, (and totally transformed the handling - it was awful before!)
Getting rid of the static sag as they did will have made it lean further. Thanks for reminding me of that, it explains a lot. So my sidestand isn't bending afterall!! :)
Si
Si
Awful handling? It probably wasn't awful... Just not as good as it is now :)
I have a 5/8" piece of plywood I use, but that's also so my stand doesn't sink into the molten asphalt we get out here in the middle of the day.
My bike leans over quite a bit. I have lots of rear ride height because I set it up that way, and also I have a huge rear tire. It seems like it leans too much with that setup.
My stand has also come a bit loose once and that caused even more lean.
Yes, these stands are silly. I think breakage is rare, but it should really be non-existant. Not rare.
No really, it was. The bike would tip the bars in when leant over and consequently try to countersteer away from the turn and stay upright. I had to really fight to stop it doing that, or crank the steering damper up too high.
It wasn't all due to setup mind. I don't think the 7 year old tyres helped much! :)
The guy at Baines said he'd never seen an MV F4 750 handle properly on standard settings, and he'd PDI's many in the past. There was an horrific amount of static sag as he showed me.
I got to ride it for about 80 miles between fitting new tyres and the setup done, and whilst the tyres helped, the handling was still pretty bad. I guess I'd been spoiled by my 748, which I'd got sorted perfectly. Since the Baines setup, my MV has been amazing, and I can see what everyone raves about. Before then I thought you were all mad... :)
Si
My 750 never handled properly until I replaced the rear spring with a heavier one. The amount of preload it took to get the static sag correct was far too much. It wasn't horrible, but far from where it should have been.
I never liked the original tires either. They had to go.
