1 - 6 of 6 Posts
How do you remove the mirror on a 1000r? I thought it would be easy, but I was stumped when I took the two bolts off. Hopefully this is not stupid question, but if any of you know, please share your knowledge. Thanks!
Juan
Un do the 2 bolts that go through the support bracket & fairing in to the mirror's, follow the support bracket down to where it fixes to the instrument cover where you will find a hex bolt. Un do this (long) hex bolt & wiggle it free, remove the rubber straps that hold the mirror wiring to the fairing bracket & un plug the wires from their connectors & you can then slip the wiring through fairing & remove mirror.
Sounds a lot more complecated than it is & in reality takes 5 minutes. Be careful when putting the long hex bolt back in, make sure it doesn't cross thread & also that the indicators work before tightening up.
Thank you for your help! I will attempt to take the mirror off in the morning. I will let you know how well it goes. I need to take it to the paint shop to have the Tamburini signature clear coated. Thanks again!
Anthill, I'll try to do this tomorrow. so you don't have to remove the whole front fairing? thanks,
jm
1 - 6 of 6 Posts
