Curious as to how it comes off. Want to do some paint work to the air inlets on it but have no idea how to remove it.
IIRC, there are 3 screws from below that you need to remove. It is easiest if you take the headlight off to get to them all. To remove the headlight there are the 2 allen screws, one on each side.
Yep, what he said :)
If I recall the is only one screw holding the digital display In place, the other fixings are just rubber grommets? Then if you move the display out of the way there are three screws holding the plastic shroud faring in place?
