1 - 1 of 1 Posts
how many mistakes do you see?
http://www.youtube.com/watch?v=wQD_aaaNmx4
What a fucktard......
the least of his sins using a ball end Allen wrench when not necessary
can't safety wire either
and the CS sprocket is done
rebuilding a motor......with used pistons?
dummy you put the pistons squarely in the bore with the inside clip in 1st
watch his bolt torque patterns....that in the manual?
cylinder studs are wrong
didn't remove clutch as an assembly......dumb
1 - 1 of 1 Posts
