1 - 20 of 26 Posts
Had a quick search without success as to how to reduce the amount of heat transfer to your and your pillion's backside. Doesn't bother me so much but my young bloke will begin to not look forward to coming for a ride with dad if it can't be alleviated.
Heading into summer now too so if something could be done It would be great.
Thanks in advance
Discussion Starter · #3 ·
OK.....So did you make that up yourself or is that a purchasable item?
OK.....it was enough of a disappointment that a thread titled "Hot Ass" has taken this unfortunate turn, and now Big Man is throwing his comments in as well......:stickpoke
That is a purchaseable item....self adhesive heat barrier. It comes it sheets from several different manufacturers or suppliers.
Randy, yes that is a double entendre all by itself...I can be civil, if I try....:smoking:
Meh. Had my hopes up too. :ahhh:
Discussion Starter · #7 ·
I see it now......at first it looked like something that was cut to shape and sewn around the edges of the holes and outer edges, but I realize now that it has been cut to fit the existing moulded panel under the seat and stuck on.
I've seen this stuff on EBay. Cool! (pardon the pun) thanks for that silentservice703
It also helps if you heat wrap the mid pipe and some of the tail pipes, as far as you can go at least. Combined with what Chuck's showing you, makes a difference.
What I did was to first attach the heat shield to the under side of the tray. Then, I used a precision knife to do the cut outs.
That is a Carbon Fiber under tail tray.:smoking:
Discussion Starter · #11 ·
Thanks Donsy for that suggestion. Will do also.
Damn I was hoping for some nude pics oh well can't win all the time LoL
1st ceramic coat your pipes...
line the bottom of underseat tray with a thermal barrier.....
check with Summit Racing
the turbo folks use a dimpled (for lack of a better word) aluminum panel which is formable....put that over the thermal barrier
my neighbor turboed 100s of vehicles.......his suggestions and he gave me water formable 3/16" asbestos :naughty:
blocks the heat of a cutting torch........
:drummer:
Now, we're getting on track here.....:)
Glad you enjoyed that Randy........
here you go Randy.......my Sweetie Pie Alex
https://fbcdn-sphotos-g-a.akamaihd...._=1422182840_7fe83d23688795015d0acc943ed2a5f0
https://fbcdn-sphotos-h-a.akamaihd...._=1422373920_6bacd4fa307f2abb8140ef0445730731
you should see the conversation about that picture LOLOL
as talented as she is beautiful
https://fbcdn-sphotos-b-a.akamaihd...._=1422327721_bee478bf5d5aac45ed303b4664aac6d0
we Skype till o'dark o'clock
:drummer::drummer:
needless to say she's the wallpaper on my phone
:naughty::naughty::naughty:
a different picture :):):)
And here I thought all the good pics were for paying members now we're on the right track
1 - 20 of 26 Posts
