So I installed a new headlight on my 08 910 having dropped my old one (yay) and I can't get the high beam to work. The new headlight is the "newer style" and came with a wire harness adapter to fit into the headlight and the OEM loom. Everything else works fine, including low beam and LED daytime running light.
I checked the fuse (replaced nonetheless) and the bulb (replaced as well), and even switched the wires on the bulb thinking they were installed incorrectly at the factory.. All I can think of is the wire is crossed on the loom adapter? Anyone else run into this replacing a headlight with a newer one?
Discussion Starter #2
Thanks to the ohm gauge I found the issue- bad connection at harness.
Nice work!
It's always something simple....just finding that simple thing is not always so simple. :banghead:
