I need the internal diameter of the left side of the axle shaft on the front end of a Marzocchi fork measured in thousandths. It is approximately 1 7/32" but I need an exact measurement. Note the left side and the right side measurements are different with the left being a little smaller. Thanks to anyone who can help.
you mean the axle extensions, that usually have to be removed for the front wheel to be balance w/ a new tire?
one is silver, the other is goldish?
i can get you that number later tonight off my F4 1k.
alex
Yeah, that's it. The size of the "hole" in the left side of the front axle assembly with the tire and everything installed on the bike, IOW in "ready-to-run" mode. Thank you!
