1 - 6 of 6 Posts
Hello all i have a problem on my 2009 1078 brutale. After running the bike nearly out of fuel and now after refuelling she wont start, it sounds like the fuel pump is priming and after a few times turning the ignition on and off she will run for a few seconds and then stops, also theres quite a bit of smoke upon the short start up . any help would be gratefully received as i have no clue where to start.
Wouldn't it be nice if we knew what year and model bike we were remotely diagnosing?
Fuel Tank and System
I don't know when, if ever, you have changed your Fuel Filter or Fuel Lines...but that is where I would start.
Drain and remove your tank, remove your fuel pump plate and check or renew the circled items.
Nice to know!
1 - 6 of 6 Posts
