1 - 20 of 37 Posts
Pretty simple, i need to change the springs on my forks. hard part is actually finding a set. also the springs need to be adequate for my weight. i've tried Marzocchi-USA in CA, CSR suspension in IN, local dealer and pretty much so far i've gotten no where. i have a 05 F4 1000s. im looking for a spring for rider of weight between 200 to 230lbs, or even a lil more weight :banghead:, Currently Knurl, and silentservice are looking into this. but hopefully they dont have to work as hard and someone else can also help. ANYONE please help out.
PS. i will also need help with the rear spring. i believe i can use an ohlins spring but to me is not clear if i may need a spacer...
Talk to Chuck about which springs he used in his forks and where he got them.
I have a shock on the SPR I brought in. It has an ohlins spring on it. Here is the spring number: 01091-39/110 /203. Donsy says it's for "a fat arse", but I don't know for sure.
ok i have some info regarding that spring. 1091 is the diameter and lengh(160mm) of spring, the -39 is the spring rate which is
N/mm---------Kg/mm----------lbs/inch
-39===110-----------11.21-----------628
Lol
Back schock springs in n/mm and fork springs in kg/mm. So the spring Carl has is a 110nm/mm spring.If I'm wrong here it's because the man is dictating while driving in the city.
springs?
an Ohlins series 1091 spring is 57mm ID and 160mm long
1091-39/110-xxx
the 39 is an Ohlins number for the spring rate it is NOT the rate, the rate is 110 N/mm
the xxx is a production code date
1091-39/110-xxx
And how does this compare with all the stock spring dimensions I sent you? Are the stock springs the same length and id?
I still don't have any idea what the spring rate is on the stock springs.
Hhhmm
Someone was going to send me the formula on how to work it out.
But I had 4 or 5 different springs here from F4's and Brutale's and ID was all 57 mm obviously, lengths varied give or take 5mm (155 - 165mm).
The spring thickness was where the difference was most obvious, which I am sure you noticed Carl. If only we knew what they were.
I know when I had the gentleman Dave's Ohlins last year his 100N/mm spring was too light for me, so a 110N/mm like this would be a step in the right direction. It might be a bit heavy for Carlos but I see he is trying to catch up to me in girth :naughty:.
Dons i might be pass you, im currently give or take 240, ive lost 20lbs, and trying to get to low 200s, hahaha, so i guess that spring will work for me then. cool :yo:Carl if you havent gotten rid of it, put my name on that too.
YOur name is on it.
Noel as the formula, but he guards it closely. Runs some bs by me about how it was on his calculator and he needs to program it.
The formula is all over the internet, it's not hard to find. But the missing variable, which none of us know or can measure is the tensile strength or something of the steel. Noel says it doesn't matter, but he doesn't know what the number is either.
I sent him a list of spring diameter on the various shocks. Curiously, the thinnest spring was on a 1078 Brutale. Thinner by a lot, too.
Carlos, I just spoke with Marzocchi an dthe guy I need to..or you need to..talk to is Mike G. Unfortuantely he is out until Monday. Noel is also working on this for you.
I think I have the right part number for my set-up and we're checking on that. The spacer you would need for the rear, if you go Ohlins or another 160mm spring is 5mm.
Here is a spacer picture...
What you should really do is come down and ride my 312R and see if this setup suits you...:f4::f4::f4:
sweet that sounds like a awesome idea :mouthwate :f4:ill make sure to treat her well, lol. by the way after 4 days of calling i got in contact with ferracci which steve also reminded me to do (from local dealer)
and they said that they dont know when they will be able to get an appropiate spring for me, But what would help is a spring from the tamburini which is stiffer than the original spring. so worst case scenerio is a tamburini spring.
Hey Kreativ, you might want to give these guys a try:
CannonRaceCraft: 405-524-7223, or look-up their web-site.
I got a quote for $130-$150 for Custom Springs.
I planned on sending them the stockers, have them rated, and then get them to wind me-up some stiffies.
But haven't got to it yet, (funds).
Maybe you could Blaze the Trail and let us know how it goes?
Discussion Starter #15
yeah i heard that option several times, but everyone also tells me that quality is poor. which is a BIG NO NO for me:cross:. We'll see what happens maybe the Knurl has something up his sleeve to help out. and again worst case scenerio would be to get some tamburini springs and adjust the preload.
The SHAPE is the issue....
Gents, the other thing to keep inmind is the designSHAPE of the Marzocchi spring. It is an expanding/declining design and straight springs, such as Ohlins, have interferences with the dampening rod that travels internal to the spring winding.
See the shape?
And here's a rear spring comparison with a clear shot of the spacer:
The WHITE spring is the one on my 312R.
Cheers Mate
My AGO and 1000R fork springs look completely different Chuck, at least that is what it looks like to me, a progressive spring but more so on the top and no taper at the bottom. Or is it just photo trickery ?
What a great picture, Dons!
I think it may just be photo trickery.
In either case, Ohlins springs and others do not have the progressive tapering....
Yup
I know, I have done the run around before. I hope Carlos finds something.
I am actually very happy with the AGO springs and spacers with a bit more oil and good quality oil.
Can you imagine my face the first time I pulled those forks apart and put them next to the 1000R forks, I was like a kid in a Candy store man.
I just re-read and looked at the picture again. Which is th Ago and which is the 1000?
The springs on the left have many more windings and a thicker wire diameter; therefore a higher spring rate...
1 - 20 of 37 Posts
