Hey,
My brutale wont' start.. I don't hear the fuel pump prime. I just put in a new battery, and accidentally put the positive on the negative, and vis versa for a moemnt which caused a spark, then corrected it.. Now the pump won't prime..? Any ideas? Fuse might have blown? What should be my first steps and where are the fuses located?
Thanks a bunch guys
Yes, you should have kept the F4 instead of flipping it.
Sounds like you fried the diode.
Hey,
Thanks a bunch guys
Hi,
Most likely the fuse under the rider seat is blown - its located next to the battery toward the rear light. There are two fuses, one is a spare.
