Hi,
I use an AGV K5 S helmet in ML size. The circumference of the head (taken in this way http://store.momodesign.com/Contents/Images/helmet-sizes.png ) is 56.5cm.
When I went to the shop to buy the helmet I felt the size MS (right for head circumference of 57cm) but I noticed a compression at the top of the head and then the shop manager advised me the size ML (right for circumference of head of 58cm).
I am using the helmet for several months but i noticed two things:
1) The housing for the intercom speakers does not coincide with my ears (so I had to position them lower than the helmet housings)
2) When I'm on the read the helmet slides down slightly and when I'm in the hull I see the road through the top of the visor.
In your opinion, regardless of the size talk (why it can depend on the shape of my head and so the ML size is perhaps correct) those two things I notice you feel normal?
