My vest connection matches the battery tender plug. Use it all the time. Its so much better riding comfortably!
As long as your accessories plus your bike aren't pulling more power than your bikes charging system can generate you shouldn't have an issue, otherwise your second start might be a jump start![]()
Might also be good practice to plug in once the bike is running to give the bike full use of the battery for starting.
Thanks Triple!My vest connection matches the battery tender plug. Use it all the time. Its so much better riding comfortably!
Thanks Triple!
Hows the weather on the Island? It's freezing temperature here on the lower mainland...
here you go Donsy;I need leather with built in air-conditioning (Cooling) instead. Good advice from Reckler.
