1 - 3 of 3 Posts
I have been reading about exhaust servo eliminators like the ones offered by Healtech. It produces a more throaty sound at idle and low revs which is what I'm looking for in my TV whilst still using the factory pipes. The device prevents the FI from coming on when you release the spring to keep the exhaust valve open.
Since the Healtech site doesn't list one for the TV except for the F3, I emailed them about it. This was their response:
"Hello,
Thank you for the email.
This kit should work with your bike, part no.:
ESE-A01
MV Agusta bikes are non-consistent so it can happen that the ESE works perfectly but it can also happen that it won't work properly on your bike.
Unfortunately, the only way to be sure is to try."
Anyways I also had a cursory look at the TV's exhaust system but don't see the valve mechanism. Does anyone know where it is located?
Pretty certain that the TV doesn't have an exhaust valve. Never noticed any cabling or a servo.
Hmmm ... looks like we are stuck with the tractor/diesel note at idle and low revs unless we gut the cat or change to an aftermarket exhaust like yours.
1 - 3 of 3 Posts
