Hey yall on my way to work this morning I decided to take the scenic route and right as I entered a my favorite fast s-curve I turned off my high beam and realized my that my low beam bulb had just burnt out. Let me tell yall finding yourself at somewere around 80-90 in the dark, balls deep in a curve with a tinted sheld on your helmet and someone turns the lights out can scare ya for a second. Soooooo heres the question is the low beam bulb something I can get off any auto parts store or is it something they will have to order from Italy.(Hopefuly its a common bulb) >>>>>>>>>>>>>>>>Thanks>in>advance>>>>PILLAR
The low beam bulb for my 06' 910S is H7 (high beam is H9) (it also says it on the headlamp glass). Both are easy to find at any major auto parts stores, unless you want to go for premium stuff. Check to see if that's what it says on yours. Hope this helps.
dave h said:
Maybe you shouldn't ride at night with a tinted shield going 90 mph in a turn. Just a thought!
NOW,NOW, go easy on him I'm sure he added some MPH to make the story a little more exciting. As for smoked shield WHY?? At night.
THANKS DSMVBRUT, That what I needed, Oh and CHB I just keep the sheild on there TX is alot closer to the sun than NJ. As for the speed I'm estimating I dont watch the speedo when I'm runnin,,,Its unsafe>>>>>>Thanks Yall PILLAR
I just purchased an H7 bulb for my low beam and the connections for the plug don't line up. The H7 bulbs electric prongs are closer together than the wire plug that connects to it. Am I missing something?
