1 - 6 of 6 Posts
Hello All
Does anyone know what is required to make a French-registered F4 meet the U.K. requirements?
The speedometer is one requirements but that can easily be done on the electronic menu.
As far as I can see the only mechanical change is the dipped beam direction. Or is it a flat-beam as standard on the F4 in which case no changes to the headlight are required.
It will probably need an SVA test because I do not have the original CoC
Anybody?
Regards
David
:f4:
Hi David,
The UK models have a different headlamp assembly, they are marked "UK" in the casting under the headlamp glass, I happen to have a spare if you get stuck.
Regards jimboF4
Hello Jimbo
Thanks for that
I might still have the option to keep the bike in France. I will know more by the end of June.
If not then I may be interested in your headlight.
David
Hello All
Anybody?
Regards
David
:f4:
Google importing a vehicle from france to uk DVLA for the red tape. I have found in the past that calling into a DVLA office cuts to the chase and they have always been very helpful to me at Garretts Green, Birmingham.
and don't neglect to remove the string of onions from the handlebars ; )
:naughty:
Strangely - the bike did not have any onions when i picked it up? I had a feeling there was something "missing"..Maybe I should have complained...??:))))))
1 - 6 of 6 Posts
