1 - 6 of 6 Posts
F3 800
I have a problem when tight the head on my F3 800. The manual say the torque at the final 85° tight must be between 53.5 and 61.5Nm but i'm around 30Nm! I change the gasket and bolt, that the second time i do that and same problem. I'am doing something wrong? I can repeat the sequence from the start without changing the new gasket?
Are you using a good digital torque wrench that reads in degrees? or making a paint mark and estimating the degrees ?
What is the torque value before the turn 85° more?
I've done lots and lots of MV engine rebuilds. Only use light motor oil on the head bolt threads. The initial torque in the manual is not enough to compress the head gasket. So do initial torque twice, then do the 85 degrees. Then go back and torque all bolts to minimum spec.
F3 800
Discussion Starter · #4 ·
The torque value before the 85° is 10Nm, then I use an angular disc and the torque wrench to supervise the torque.
Thank you! That's what i think the pre tightening torque is not enought. Just for clarity, you do the initial torque at 20Nm then 85°, release the bolts and 10Nm+85°?
1 - 6 of 6 Posts
