1 - 12 of 12 Posts
Just as the topic says, Have you done it and where did you buy your sprokets from? Best available?
Also, I have the 1078, has anyone tried different teeth count and gotten better performance?
What should the oil level be in the 50mm Marzocchi forks? My fork seal has been leaking and I am getting them changed out. Thanks.
Just as the topic says, Have you done it and where did you buy your sprocket's from? Best available?
I run 520 on my F4 without any problems, same sprockets as your bike. I got mine from Al at Design Corse as well as the chain. I use Talon Sprockets and RK chain which are available pretty much from any of the site sponsors. Make sure you have a decent chain joining tool as you will be fiddling with chain lengths if you are going to change ratio's.
When you say you want more performance, what do you mean ? The feeling of more power - ie even quicker revving. Or lower revving better fuel economy - more top speed ? Leave the the steel front sprocket at the same size (15th I think) when you change to 520 pitch, but at the back - bigger will make it stand up on the back wheel even quicker - smaller will give you lower revs. I think you run a 42 or 43 on the back already and that is pretty insane on the 1078 I thought.
As far as the forks go, can't help you there as I have been asking for someone with a workshop manual to post it up for us for month's with no help forthcoming. You might have to ask a dealer for help there. If push comes to shove, I would measure the oil in the non leaking fork get an idea and go from there. Or download the manual for the F4 1078 RR and maybe someone can tell us if the fork oil levels are the same - http://my.agusta.us/
Good luck mate.
I'm 15/41, don't need it to stand up any quicker than it already does, is already insane. Yeah we were gonna measure the non leaking fork and go from there. Motovation was put on the project, the only place that had 520 this for the bike is Drive Systems USA $89.95 for rear, $38.95 for front. With the EK Triple Z Gold chain.
I ride hard and fast, some track days, mostly 3-4 hr stretches through the curviest roads I can find, don't care about fuel economy, (I mean really? If that was a concern, would we have these bikes. :) )
Well what did you mean then, when you said you wanted more performance,that is all you can achieve with changing sprockets. http://www.designcorse.co.uk/Mv_Agusta_Chains_Sprockets/Talon_Rear_Sprocket
I'm making it a street legal version of the Challenge Brutales. Just trying to get as much performance as I can out of it. Acceleration, less weight, faster shifting. TI Exhaust on the way, PC V, and a quick shifter to come. I'm doing the Schwann's Racing school next summer over here and track days.
I have a 520 on my '04 750. I didnt do the conversion myselfs so I cant really tell you anything about it sorry.
750 model has factory installed 520 chain, while the rear sprocket change complete with carrier (unfortunately) much more expensive than the 525 on stronger models MV-A.
On my 750 I've changed only the front sprocket from 14 to 15 teeth because when fully open titanium exhaust, different EPROM and air filter are combined, 1st, 2nd and sometimes 3rd gear is all too often ended up with a wheelie :smoking:
It has also improved fuel consumption.
For the calculation I used http://www.gearingcommander.com as on previous bikes because they have a good database and the possibility of manually entering parameters.
Okay
I would go to a 42 or 43 rear but stay with the 15 front (new 520 pitch of coarse). Would not worry about PC but get a Microtec ECU instead, much smoother operation with a quickshifter too.
You already have the later version of the sprocket carrier so you don't need any other than chain and sprockets.
I'd like to add that a 520 RKxring chain and aluminum Sprockets from EvolutionBike were about 3.5 lbs lighter than the Stock Chain and Sprockets on my Y10 F4.
I'm Hopeing to get Fatty down to about 410 lbs. But, like a beautiful stripper, I'll have to keep throwing money at her to make it happen, of she just sits there looking extremely sexy.
Thanks, used this to get the right levels. Replaced all oil in both forks. Was thick and stringy, replaced with race fork oil. Set suspension stiffer, feels great. 520 kit on its way from the company that makes the sprokets for the Corse bikes. Have a great super light chain. Can't wait to get em on. Full Ti system in route as well. An early Christmas for me. :)
1 - 12 of 12 Posts
