@FlashVinnig -- Choose to believe what you will
.. But none of the stuff you are so dependent on in your everyday life, like your smartphone or the electronics in your MV would be here if not for the advancement of Science and "men in white coats" .. -- It did NOT come about by "having faith in God" or any such superstitious nonsense .. You just set about proving the existence of "god" and when you do, I'll concede to "faith" .. so far its been "Science: 1000000000000 points - "God/Allah/Jahve" - 0 points
Not even your "skunk" is the work of "god" -- That was refined by "men in white coats" -
Climate change is REAL -- Geology as a Science is REAL -- We CAN know what the world looked like millions of years ago - the proof is right under our feet -- in the ground .. You can dig out the fossils, and measure the chemistry -- You do not even need to "believe" -- You can just go look for yourself -- Its not hard.. The CO2 levels you can track yourself! Just go buy a Dräger CO2 gas analyzer and start taking measurements .. Note them down and see which way it goes over the next couple of years -- Its no harder than measuring the voltage of your battery or the temperature in your skunk greenhouse -- Science is simple!
BTW: the CO2 levels will be lower and the O2 levels will be higher in your greenhouse -- Thats what plants do - They live off CO2, water and minerals and sunlight, and they produce intoxicating carbon-based molecules and excrete O2 --
