Hello fellow riders,
I'm Johannes and i own a 2017 Brutale 800, I got it late last season and am dying to get back out there (snow here atm).
So fare no major issues, got a small leak in the front brake a few weeks in, but warranty got that fixed.
I have a question about the inside diameter of handlebars? I want to order some new bar end mirrors(7490-viper).
My tools haven't arrived yet and i cant seem to get the ends of with a normal screwdriver.
With much love -J
First...Welcome to the family.
Interesting name you have chosen...??
I believe the bars are standard size and inside diameter will be the same as most other bikes with this type handlebar (Ducati monster etc). The bar ends are probably held by an expansion bushing. You loosen the bolt in the end and then push inward before trying to pull out.
@GizmoTheBallLess: If the design hasn't changed it is probably a compression fitting inside the tube. You would rotate the "bolt" several times counter-clockwise and then pull it out. The friction hold can be strong.
