1 - 2 of 2 Posts
I'm about to install a Gipro X-type gear indicator to my wife's Brutale S and am wondering if there are fitting tips anyone could share with me.
Can someone also tell me where the RPM/Timing sensor connector is located?
Which switched 12v power wire can I connect the Gipro feed wire to, using a wire tap connector?
Thanks in advance.
Discussion Starter #2
I managed to fit the gear indicator at the weekend. Pretty straightforward fit with no drama. :crazyeyes
1 - 2 of 2 Posts
