I guess this one is aimed at Donsy and Noel as I'm not sure who else has had a gearbox in pieces....
The replacement I bought from Time Machine Bikes was no good as it would appear the R312 has larger shafts than the 1000S & R. Lesson learned..
I'm hoping that replacing all of the needle roller bearings (8000A0370 ) in the main and counter shaft will solve the wining gearbox. (2 on the main shaft and 4 on the counter shaft)
If the 2 main bearings in the case look OK (8000A1086 & 8000A2318) feel OK should these be replaced also? Should I replace the 2 seals (800064296 & 800089410) while I have it in pieces?
J
J
