Hi.
So I have an issue with the gear shift indicator on 1st gear.
When the bike is not running but I turn it on ( not yet engine ) it recognizes first gear, second and any other it would need..
As soon as I start the engine, it shows the first gear as neutral. All the other gears are fine 2,3,4,5,6... 1st gear works, I can drive, but it gives me neutral on screen. Wouldn't be a problem, but I have to do an inspection and bike has to turn off if kickstand is down and you put in 1st gear. As the ECU thinks it's in neutral - nothing happens.
I have changed gear sensor with the cables.. that didn't help the issue.
Could it be some "glitch" in ECU and I might have to reset it? Something else?
The official dealer has no answers to this problem.. and again, I wouldn't care about it too much, but can't do an inspection for the bike.
MV Agusta 800 brutalle 2013.
